Niferman
Niferman » Пт май 12, 2023 12:24 pm
В разделе безопасность-антивирус, пишет что сервис не установлен.
Нажимаю установка антивируса. Выдает ошибку. Точнее говорит что установлен, но в логе ошибка. Вот лог
%5B%7B%22comm%22%3A%22%5C%2Fusr%5C%2Flocal%5C%2Fbrainycp%5C%2Fssh%5C%2Fpacket_manager%5C%2Fclamav%5C%2Fclamav.sh+install%22%2C%22array_succes%22%3A%7B%22status_clamav%22%3A%22success%2C%23stream_id%23%22%2C%22clamav%22%3A%221%22%7D%2C%22array_start%22%3A%7B%22status_clamav%22%3A%22inprogress%2C%23stream_id%23%22%7D%2C%22array_unsucces%22%3A%7B%22status_clamav%22%3A%22unsuccess%2C%23stream_id%23%22%7D%2C%22test%22%3A%22Complete%22%2C%22userowner%22%3A%22root%22%7D%2C%7B%22comm%22%3A%22%5C%2Fusr%5C%2Flocal%5C%2Fbrainycp%5C%2Fssh%5C%2Fpkg_manager_init.php+-a+update_file_config%22%7D%2C%7B%22comm%22%3A%22%5C%2Fusr%5C%2Flocal%5C%2Fbrainycp%5C%2Fsrc%5C%2Fcompiled%5C%2Fphp5%5C%2Fbin%5C%2Fphp+-q++%5C%2Fusr%5C%2Flocal%5C%2Fbrainycp%5C%2Fscripts%5C%2Fcluster.php+-a+sinhronisation_cluster+-f+%27packet%27%22%7D%5D/etc/brainy/conf/streams/packet_manager2_control_168389377036126
/usr/local/brainycp/ssh/packet_manager/clamav/clamav.sh install
Little RAM, > 2.5G or more required. Denied installation.
- Снимок.PNG (15.3 КБ) 21815 просмотров
Niferman
Niferman » Пт май 12, 2023 12:29 pm
Вопрос снят. Извиняюсь пропустил момент с нехваткой памяти...
Niferman
Niferman » Пт май 12, 2023 12:30 pm
Но вот теперь проблема с fail2ban
%5B%7B%22comm%22%3A%22%5C%2Fusr%5C%2Flocal%5C%2Fbrainycp%5C%2Fssh%5C%2Fpacket_manager%5C%2Ffail2ban%5C%2Ffail2ban.sh+install%22%2C%22array_succes%22%3A%7B%22status_fail2ban%22%3A%22success%2C%23stream_id%23%22%2C%22fail2ban%22%3A%221%22%7D%2C%22array_start%22%3A%7B%22status_fail2ban%22%3A%22inprogress%2C%23stream_id%23%22%7D%2C%22array_unsucces%22%3A%7B%22status_fail2ban%22%3A%22unsuccess%2C%23stream_id%23%22%7D%2C%22test%22%3A%22Complete%22%2C%22userowner%22%3A%22root%22%7D%2C%7B%22comm%22%3A%22%5C%2Fusr%5C%2Flocal%5C%2Fbrainycp%5C%2Fssh%5C%2Fpkg_manager_init.php+-a+update_file_config%22%7D%2C%7B%22comm%22%3A%22%5C%2Fusr%5C%2Flocal%5C%2Fbrainycp%5C%2Fsrc%5C%2Fcompiled%5C%2Fphp5%5C%2Fbin%5C%2Fphp+-q++%5C%2Fusr%5C%2Flocal%5C%2Fbrainycp%5C%2Fscripts%5C%2Fcluster.php+-a+sinhronisation_cluster+-f+%27packet%27%22%7D%5D/etc/brainy/conf/streams/packet_manager2_control_168389449530903
/usr/local/brainycp/ssh/packet_manager/fail2ban/fail2ban.sh install
Complete
Run process...
Process completed.
Niferman
Niferman » Пт май 12, 2023 12:31 pm
Прям мистика, как напишу на форуме, потом нажимаю установить - все ставиться...
