pomoyka
Сообщение pomoyka » Пн июн 24, 2024 10:47 am
root@hope:~# systemctl status atd
● atd.service - Deferred execution scheduler
Loaded: loaded (/lib/systemd/system/atd.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2024-06-24 13:34:56 MSK; 3min 16s ago
Docs: man:atd(8)
Process: 1069 ExecStartPre=find /var/spool/at/atjobs -type f -name =* -not -newercc /run/systemd -delete (code=exited, status=0/SUCCESS)
Main PID: 1105 (atd)
Tasks: 1 (limit: 14832)
Memory: 576.0K
CPU: 6ms
CGroup: /system.slice/atd.service
└─1105 /usr/sbin/atd -f
Jun 24 13:34:56 hope
1. failed to star /etc/rc.local compabillity (quotachek закомментировать?)
un 24 13:35:26 hope rc.local[2040]: umount: /home/user/usr/share/fonts: not mounted.
Jun 24 13:35:26 hope rc.local[2042]: umount: /home/user/usr/share/i18n: not mounted.
Jun 24 13:35:26 hope rc.local[2044]: umount: /home/user/usr/share/i18n: not mounted.
Jun 24 13:35:26 hope rc.local[2046]: umount: /home/user/usr/share/locale: not mounted.
Jun 24 13:35:26 hope rc.local[2048]: umount: /home/user/usr/share/locale: not mounted.
Jun 24 13:35:26 hope rc.local[2050]: umount: /home/user/usr/share/pki: not mounted.
Jun 24 13:35:26 hope rc.local[2052]: umount: /home/user/usr/share/pki: not mounted.
Jun 24 13:35:26 hope rc.local[2054]: umount: /home/user/usr/share/snmp: not mounted.
Jun 24 13:35:26 hope rc.local[2056]: umount: /home/user/usr/share/snmp: not mounted.
Jun 24 13:35:26 hope rc.local[2058]: umount: /home/user/usr/share/terminfo: not mounted.
Jun 24 13:35:26 hope rc.local[2060]: umount: /home/user/usr/share/terminfo: not mounted.
Jun 24 13:35:26 hope rc.local[2062]: umount: /home/user/usr/share/zoneinfo: not mounted.
Jun 24 13:35:26 hope rc.local[2064]: umount: /home/user/usr/share/zoneinfo: not mounted.
Jun 24 13:35:26 hope rc.local[2066]: umount: /home/user/usr/share/GeoIP: not mounted.
Jun 24 13:35:26 hope rc.local[2068]: umount: /home/user/usr/share/GeoIP: not mounted.
Jun 24 13:35:26 hope rc.local[2070]: umount: /home/user/usr/share/mc: not mounted.
Jun 24 13:35:26 hope rc.local[2072]: umount: /home/user/usr/share/mc: not mounted.
Jun 24 13:35:26 hope rc.local[2074]: quotacheck: Your kernel probably supports ext4 quota feature but you are using external quota files. Please switch your filesystem to use ext4 quota feature as external quota files on ext4 are deprecated.
Jun 24 13:35:26 hope rc.local[2074]: quotacheck: Quota for users is enabled on mountpoint / so quotacheck might damage the file.
Jun 24 13:35:26 hope rc.local[2074]: Please turn quotas off or use -f to force checking.
2.filed to start one-time temporary tls key generation for httpd.service
see systemctl status-init.service
Unknown command verb status-init.service.
pomoyka
Сообщение pomoyka » Пн июн 24, 2024 10:48 am
Jun 24 13:35:26 hope rc.local[1985]: mount: /home/user/usr/bin/php52: special device /usr/jail_skeleton/usr/bin/php52 does not exist.
Jun 24 13:35:26 hope rc.local[1986]: umount: /home/user/usr/bin/php53: not mounted.
Jun 24 13:35:26 hope rc.local[1987]: umount: /home/user/usr/bin/php53: not mounted.
Jun 24 13:35:26 hope rc.local[1988]: mount: /home/user/usr/bin/php53: special device /usr/jail_skeleton/usr/bin/php53 does not exist.
Jun 24 13:35:26 hope rc.local[1989]: umount: /home/user/usr/bin/php54: not mounted.
Jun 24 13:35:26 hope rc.local[1990]: umount: /home/user/usr/bin/php54: not mounted.
Jun 24 13:35:26 hope rc.local[1991]: mount: /home/user/usr/bin/php54: special device /usr/jail_skeleton/usr/bin/php54 does not exist.
Jun 24 13:35:26 hope rc.local[1992]: umount: /home/user/usr/bin/php55: not mounted.
Jun 24 13:35:26 hope rc.local[1993]: umount: /home/user/usr/bin/php55: not mounted.
Jun 24 13:35:26 hope rc.local[1994]: mount: /home/user/usr/bin/php55: special device /usr/jail_skeleton/usr/bin/php55 does not exist.
Jun 24 13:35:26 hope rc.local[1995]: umount: /home/user/usr/bin/php56: not mounted.
Jun 24 13:35:26 hope rc.local[1996]: umount: /home/user/usr/bin/php56: not mounted.
Jun 24 13:35:26 hope rc.local[1997]: mount: /home/user/usr/bin/php56: special device /usr/jail_skeleton/usr/bin/php56 does not exist.
Jun 24 13:35:26 hope rc.local[1998]: umount: /home/user/usr/bin/php70: not mounted.
Jun 24 13:35:26 hope rc.local[1999]: umount: /home/user/usr/bin/php70: not mounted.
Jun 24 13:35:26 hope rc.local[2000]: mount: /home/user/usr/bin/php70: special device /usr/jail_skeleton/usr/bin/php70 does not exist.
Jun 24 13:35:26 hope rc.local[2001]: umount: /home/user/usr/bin/php71: not mounted.
Jun 24 13:35:26 hope rc.local[2002]: umount: /home/user/usr/bin/php71: not mounted.
Jun 24 13:35:26 hope rc.local[2003]: mount: /home/user/usr/bin/php71: special device /usr/jail_skeleton/usr/bin/php71 does not exist.
Jun 24 13:35:26 hope rc.local[2004]: umount: /home/user/usr/bin/php72: not mounted.
Jun 24 13:35:26 hope rc.local[2005]: umount: /home/user/usr/bin/php72: not mounted.
Jun 24 13:35:26 hope rc.local[2006]: mount: /home/user/usr/bin/php72: special device /usr/jail_skeleton/usr/bin/php72 does not exist.
Jun 24 13:35:26 hope rc.local[2007]: umount: /home/user/usr/bin/php73: not mounted.
Jun 24 13:35:26 hope rc.local[2008]: umount: /home/user/usr/bin/php73: not mounted.
Jun 24 13:35:26 hope rc.local[2009]: mount: /home/user/usr/bin/php73: special device /usr/jail_skeleton/usr/bin/php73 does not exist.
Jun 24 13:35:26 hope rc.local[2010]: umount: /home/user/usr/bin/php74: not mounted.
Jun 24 13:35:26 hope rc.local[2011]: umount: /home/user/usr/bin/php74: not mounted.
Jun 24 13:35:26 hope rc.local[2014]: umount: /home/user/usr/bin/php80: not mounted.
Jun 24 13:35:26 hope rc.local[2015]: umount: /home/user/usr/bin/php80: not mounted.
Установлен только php 7.4 и 8.0
Сообщение sbury » Ср июн 26, 2024 7:14 am
lsblk -f
Сообщение alenka » Ср июн 26, 2024 7:34 am
Данные в rc.local добавляются в момент создания хостаккаунта, для всех версий php. Если версия установлена то она монтируется.
pomoyka
Сообщение pomoyka » Ср июн 26, 2024 7:51 am
lsblk -f
root@hope:~# lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /snap/core20/2105
loop1 squashfs 4.0 0 100% /snap/core20/2318
loop2 squashfs 4.0 0 100% /snap/lxd/27037
loop3 squashfs 4.0 0 100% /snap/lxd/28373
loop4 squashfs 4.0 0 100% /snap/snapd/20671
loop5 squashfs 4.0 0 100% /snap/snapd/21759
sda
|-sda1 vfat FAT32 AA2D-2AD3 1G 1% /boot/efi
|-sda2 ext4 1.0 e59314d2-799a-4d6c-be31-562a1d239494 1.7G 7% /boot
`-sda3 LVM2_member LVM2 001 uo2wg4-Fg0v-JX1n-Z0Aq-F5u1-My92-PB57ic
|-ubuntu--vg-ubuntu--lv ext4 1.0 0a412b71-c3c6-4115-b1e8-59455c9c2594 203.5G 12% /home/user2/usr/share/mc
/home/user2/usr/share/GeoIP
/home/user2/usr/share/zoneinfo
| /home/user2/usr/share/terminfo
| /home/user2/usr/share/snmp
| /home/user2/usr/share/pki
| /home/user2/usr/share/locale
| /home/user2/usr/share/i18n
| /home/user2/usr/share/fonts
| /home/user2/usr/share/fontconfig
| /home/user2/usr/lib
| /home/user2/usr/lib64
| /home/user2/usr/bin/php80
| /home/user2/usr/bin/php74
| /home/user1/usr/share/mc
| /home/user1/usr/share/GeoIP
| /home/user1/usr/share/zoneinfo
| /home/user1/usr/share/terminfo
| /home/user1/usr/share/snmp
| /home/user1/usr/share/pki
| /home/user1/usr/share/locale
| /home/user1/usr/share/i18n
| /home/user1/usr/share/fonts
| /home/user1/usr/share/fontconfig
| /home/user1/usr/lib
| /home/user1/usr/lib64
| /home/user1/usr/bin/php80
| /home/user1/usr/bin/php74
`-ubuntu--vg-lv--0 swap 1 d31de051-2863-458e-ac94-56a35a2c1327 [SWAP]
sr0
root@hope:~#
Сообщение alenka » Ср июн 26, 2024 11:22 am
pomoyka писал(а):
Вт июн 18, 2024 9:24 pm
Alma 9.4
servername=domenname
Уточните, вы устанавливаете панель с нашего сайта(свежую), или из восстанавливаете из образа?
На скрине один из самоподписных сертификатов, издатель Springfield. Не понятно как он был сгенерирован, и от куда он у вас на сервере данный серт.
pomoyka
Сообщение pomoyka » Ср июн 26, 2024 12:15 pm
Alma 9.4
Чистую по сгенерированной команде.
Данный сертификат присутствует всегда при установке чистой панели.!!!!!!!!!
pomoyka
Сообщение pomoyka » Ср июн 26, 2024 12:18 pm
Проверил 4 vm все устанавливал чистыми Alma 9.3 , 9.4 ubuntu 22.03 , 22.04 Везде после установки стоит springfiel.
Сообщение alenka » Ср июн 26, 2024 2:55 pm
Только что проверила, ошибки нет.
Издатель springfiel, значится до выполнения скрипта, по обновлению сертов.
Такое чувство что панель у вас не до конца установлена( возможно обрыв сессии).
Ниже на скрине, функция которая обновляет серты, при установке панели.
pomoyka
Сообщение pomoyka » Ср июн 26, 2024 3:32 pm
