Не устанавливается composer
creogen
Сообщение creogen » Вт окт 28, 2025 3:51 pm
Версия панели 1.0986
В панели через Менеджер приложений не устанавливается Composer
Лог последней установки:
/usr/local/brainycp/ssh/packet_manager/composer/composer.sh install
Warning: copy(https://getcomposer.org/installer): failed to open stream: Network is unreachable in Command line code on line 1
Warning: hash_file(composer-setup.php): failed to open stream: No such file or directory in Command line code on line 1
Installer corrupt
Warning: unlink(composer-setup.php): No such file or directory in Command line code on line 1
Could not open input file: composer-setup.php
Complete
Run process...
Process completed.
Ранее Composer не устанавливался.
