[Решено] Install Haveged... [ERROR] на AlmaLinux 9
Добавлено: Ср ноя 15, 2023 8:47 pm
Решил на тестовом VPS поставить AlmaLinux 9.3 и панелью, но вот не задача, поймал ошибку Install Haveged... [ERROR]
В файле /var/log/brainy_update.log в конце есть такое
В файле /var/log/dnf.log в конце
Failed to set locale, defaulting to C.UTF-8
Last metadata expiration check: 0:00:39 ago on Wed Nov 15 23:18:35 2023.
Package pcre2-10.40-2.el9.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!
Last metadata expiration check: 0:00:40 ago on Wed Nov 15 23:18:35 2023.
No match for argument: python2
Error: Unable to find a match: python2
2023-11-15T20:19:53+0300 SUBDEBUG
File "/usr/lib/python3.9/site-packages/dnf/cli/main.py", line 67, in main
return _main(base, args, cli_class, option_parser_class)
File "/usr/lib/python3.9/site-packages/dnf/cli/main.py", line 106, in _main
return cli_run(cli, base)
File "/usr/lib/python3.9/site-packages/dnf/cli/main.py", line 122, in cli_run
cli.run()
File "/usr/lib/python3.9/site-packages/dnf/cli/cli.py", line 1057, in run
return self.command.run()
File "/usr/lib/python3.9/site-packages/dnf/cli/commands/install.py", line 118, in run
raise dnf.exceptions.PackagesNotAvailableError(_("Unable to find a match"),
dnf.exceptions.PackagesNotAvailableError: Unable to find a match: haveged
2023-11-15T20:19:53+0300 CRITICAL Error: Unable to find a match: haveged
