Невозможно установить Fail2ban
Добавлено: Вс ноя 15, 2020 11:37 am
Здравствуйте. При попытке установить fail2ban ничего не получается. Лог:
ВПС взята у firstvds. Как быть и что делать?
* base: mirror.docker.ru
* extras: mirror.reconn.ru
* updates: mirror.reconn.ru
Resolving Dependencies
--> Running transaction check
---> Package fail2ban.noarch 0:0.9.7-10.el7.centos will be installed
--> Processing Dependency: fail2ban-server = 0.9.7-10.el7.centos for package: fail2ban-0.9.7-10.el7.centos.noarch
--> Processing Dependency: fail2ban-sendmail = 0.9.7-10.el7.centos for package: fail2ban-0.9.7-10.el7.centos.noarch
---> Package fail2ban-sendmail.noarch 0:0.9.7-10.el7.centos will be installed
---> Package fail2ban-server.noarch 0:0.9.7-10.el7.centos will be installed
--> Processing Dependency: systemd-python for package: fail2ban-server-0.9.7-10.el7.centos.noarch
--> Processing Dependency: ipset for package: fail2ban-server-0.9.7-10.el7.centos.noarch
---> Package ipset.x86_64 0:7.1-1.el7 will be installed
--> Processing Dependency: ipset-libs(x86-64) = 7.1-1.el7 for package: ipset-7.1-1.el7.x86_64
--> Processing Dependency: libipset.so.13(LIBIPSET_4.8)(64bit) for package: ipset-7.1-1.el7.x86_64
--> Processing Dependency: libipset.so.13(LIBIPSET_2.0)(64bit) for package: ipset-7.1-1.el7.x86_64
--> Processing Dependency: libipset.so.13()(64bit) for package: ipset-7.1-1.el7.x86_64
---> Package ipset-libs.x86_64 0:7.1-1.el7 will be installed
