CPU ISA level is lover than required
greencom
Сообщение greencom » Вт янв 27, 2026 3:30 pm
Сервер - DELL PowerEdge R710
CPU - Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
Host OS - Hyper-V Server 2016
Virtual OS - AlmaLinux 10.1 - x86_64_v2
Не запускается панель после установки на чистую ОС.
14:57 Failed to start brainyphp-fpm.service - The Brainy-FPM PHP Process Manager. systemd
14:57 brainyphp-fpm.service: Failed with result 'exit-code'. systemd
14:57 brainyphp-fpm.service: Main process exited, code=exited, status=127/n/a systemd
14:57 /usr/local/brainycp/src/compiled/php5/bin/php-fpm: CPU ISA level is lower than required php-fpm
14:57 Starting brainyphp-fpm.service - The Brainy-FPM PHP Process Manager... systemd
14:45 Failed to start brainyphp-fpm.service - The Brainy-FPM PHP Process Manager. systemd
14:45 brainyphp-fpm.service: Failed with result 'exit-code'. systemd
14:45 brainyphp-fpm.service: Main process exited, code=exited, status=127/n/a systemd
14:45 /usr/local/brainycp/src/compiled/php5/bin/php-fpm: CPU ISA level is lower than required php-fpm
14:45 Starting brainyphp-fpm.service - The Brainy-FPM PHP Process Manager... systemd
Re: CPU ISA level is lover than required
Сообщение sbury » Вт янв 27, 2026 5:02 pm
покажите выводы
cat /etc/os-release
yum list installed | grep -E '(brainy-nginx|brainy-php)'
systemctl --no-pager status nginxb
systemctl --no-pager status brainyphp-fpm
rpm  -qa | grep -E '(glibc|kernel)'
А вообще панель орентирована на x86_64
Последний раз редактировалось sbury Вт янв 27, 2026 5:53 pm, всего редактировалось 1 раз.
greencom
Сообщение greencom » Вт янв 27, 2026 5:44 pm
cat /etc/os-release
NAME="AlmaLinux"
VERSION="10.1 (Heliotrope Lion)"
ID="almalinux"
ID_LIKE="rhel centos fedora"
VERSION_ID="10.1"
PLATFORM_ID="platform:el10"
PRETTY_NAME="AlmaLinux 10.1 (Heliotrope Lion)"
ANSI_COLOR="0;34"
LOGO="fedora-logo-icon"
CPE_NAME="cpe:/o:almalinux:almalinux:10.1"
VENDOR_NAME="AlmaLinux"
VENDOR_URL="https://almalinux.org/"
ALMALINUX_MANTISBT_PROJECT="AlmaLinux-10"
ALMALINUX_MANTISBT_PROJECT_VERSION="10.1"
REDHAT_SUPPORT_PRODUCT_VERSION="10.1"
SUPPORT_END=2035-06-01
brainy-nginx.x86_64 2:1.26.2-2.1.brainy.el10_10.0 @9_brainy
brainy-nginx-all-modules.noarch 2:1.26.2-2.1.brainy.el10_10.0 @9_brainy
brainy-nginx-filesystem.noarch 2:1.26.2-2.1.brainy.el10_10.0 @9_brainy
brainy-nginx-mod-http-geoip.x86_64 2:1.26.2-2.1.brainy.el10_10.0 @9_brainy
brainy-nginx-mod-http-image-filter.x86_64 2:1.26.2-2.1.brainy.el10_10.0 @9_brainy
brainy-nginx-mod-http-perl.x86_64 2:1.26.2-2.1.brainy.el10_10.0 @9_brainy
brainy-nginx-mod-http-xslt-filter.x86_64 2:1.26.2-2.1.brainy.el10_10.0 @9_brainy
brainy-nginx-mod-mail.x86_64 2:1.26.2-2.1.brainy.el10_10.0 @9_brainy
brainy-nginx-mod-pagespeed.x86_64 2:1.26.2-2.1.brainy.el10_10.0 @9_brainy
brainy-nginx-mod-stream.x86_64 2:1.26.2-2.1.brainy.el10_10.0 @9_brainy
brainy-php5.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-devel.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-enchant.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-fpm.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-gd.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-imap.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-intl.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-json.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-mbstring.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-mcrypt.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-modules-base.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-mysql.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-pdo.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-pgsql.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-process.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-ssh2.x86_64 0.13-4.el10 @9_brainy
brainy-php5-xml.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-zendopcache.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php5-zip.x86_64 5.6.40-38.brainyV3.el10_10.0 @9_brainy
brainy-php8.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-cli.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-common.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-fpm.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-gd.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-imagick.x86_64 3.7.0-1.brainy.el10_10.0 @9_brainy
brainy-php8-imap.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-intl.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-mbstring.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-mcrypt.x86_64 1.0.9-1.brainy.el10 @9_brainy
brainy-php8-modules-base.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-mysql.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-pdo.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-pear.x86_64 1.10.16-1.brainy.el10 @9_brainy
brainy-php8-pgsql.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-process.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-ssh2.x86_64 1.4.1-1.brainy.el10 @9_brainy
brainy-php8-xml.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-zendopcache.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
brainy-php8-zip.x86_64 8.1.33-2.brainy.el10_10.0 @9_brainy
greencom
○ nginxb.service - The nginx HTTP and reverse proxy server
Loaded: loaded (/usr/lib/systemd/system/nginxb.service; disabled; preset: disabled)
Active: inactive (dead)
янв 27 11:28:32 billing systemd[1]: nginxb.service: Unit cannot be reloaded because it is inactive.
× brainyphp-fpm.service - The Brainy-FPM PHP Process Manager
Loaded: loaded (/usr/lib/systemd/system/brainyphp-fpm.service; disabled; preset: disabled)
Active: failed (Result: exit-code) since Tue 2026-01-27 14:57:12 EET; 2h 59min ago
Invocation: 895e2076a75b41f5830e1bafea111865
Process: 36283 ExecStart=/usr/local/brainycp/src/compiled/php5/bin/php-fpm -R --nodaemonize (code=exited, status=127)
Main PID: 36283 (code=exited, status=127)
Mem peak: 2.9M
CPU: 16ms
янв 27 14:57:12 billing systemd[1]: Starting brainyphp-fpm.service - The Brainy-FPM PHP Process Manager...
янв 27 14:57:12 billing php-fpm[36283]: /usr/local/brainycp/src/compiled/php5/bin/php-fpm: CPU ISA level is lower than required
янв 27 14:57:12 billing systemd[1]: brainyphp-fpm.service: Main process exited, code=exited, status=127/n/a
янв 27 14:57:12 billing systemd[1]: brainyphp-fpm.service: Failed with result 'exit-code'.
янв 27 14:57:12 billing systemd[1]: Failed to start brainyphp-fpm.service - The Brainy-FPM PHP Process Manager.
greencom
Сообщение greencom » Вт янв 27, 2026 5:45 pm
glibc-gconv-extra-2.39-58.el10_1.2.alma.1.x86_64_v2
glibc-2.39-58.el10_1.2.alma.1.x86_64_v2
glibc-common-2.39-58.el10_1.2.alma.1.x86_64_v2
glibc-langpack-ru-2.39-58.el10_1.2.alma.1.x86_64_v2
kernel-tools-libs-6.12.0-124.28.1.el10_1.x86_64_v2
kernel-tools-6.12.0-124.28.1.el10_1.x86_64_v2
kernel-modules-core-6.12.0-124.28.1.el10_1.x86_64_v2
kernel-core-6.12.0-124.28.1.el10_1.x86_64_v2
kernel-modules-6.12.0-124.28.1.el10_1.x86_64_v2
kernel-modules-extra-6.12.0-124.28.1.el10_1.x86_64_v2
kernel-6.12.0-124.28.1.el10_1.x86_64_v2
kernel-srpm-macros-1.0-25.el10.noarch
kernel-headers-6.12.0-124.28.1.el10_1.x86_64_v2
glibc-devel-2.39-58.el10_1.2.alma.1.x86_64_v2
kernel-modules-extra-matched-6.12.0-124.28.1.el10_1.x86_64_v2
Сообщение sbury » Вт янв 27, 2026 5:58 pm
Скорее всего в этом проблема x86_64_v2
Сборка орентирована на стандартную(базовую) архитертуру x86_64
greencom
Сообщение greencom » Вт янв 27, 2026 7:02 pm
Разница между x86_64 и x86_64v2:
Поддерживаемые инструкции:
x86_64 (v1): Базовый 64-битный набор (AMD64/Intel64), выпущенный примерно после 2003 года.
x86_64_v2: Требует дополнительно: CMPXCHG16B, LAHF-SAHF, POPCNT, SSE3, SSSE3, SSE4.1, SSE4.2.
Производительность: Программы, скомпилированные для x86_64_v2, могут работать быстрее на более новом оборудовании благодаря оптимизации под современные наборы инструкций.
Совместимость: Программа, оптимизированная под v2, не запустится на очень старом процессоре (до 2008–2010 годов), который поддерживает только базовый x86_64.
Контекст использования: Уровни v2, v3, v4 часто используются в современных дистрибутивах Linux для оптимизации пакетов под современные процессоры.
Итог: x86_64_v2 — это оптимизированная версия для процессоров примерно 2010 года выпуска и новее, обеспечивающая лучшую производительность по сравнению с базовым x86_64 (v1)
Ребята, вы отстаете...
x5650 вроде уже давно устаревший проц, но он как раз в ОС с поддержкой x86_64_v2 покажет себя более шустрым за счет новых инструкций (SSSE3, SSE4.1, SSE4.2). Стоит ли ожидать исправлений? Да и то AlmaLinux даже от этих процов скоро откажется.
greencom
Сообщение greencom » Вт янв 27, 2026 7:32 pm
Для установки панели я использовал команду
wget -O install.sh http://core.brainycp.com/install.sh && bash ./install.sh --package=apache2.4,nginx,php82w,php83w,php84w,bindserver,ffmpeg,imagemagick,certbot,logrotate,composer,fail2ban,MariaDB10.5,phpMyAdmin-4.9.4,exim,spamassassin,clamav,proftpd
Версию php5.6 и более ранние исключил. Но почему при установке использует запуск юнита из папки php 5? (usr/local/brainycp/src/compiled/php5/bin/php-fpm)
Сообщение sbury » Ср янв 28, 2026 3:34 am
Панель ориентирована на поддержку всх процессоров включая v1. У AlmaLinux 10 такое разделение приводит к бинарной разнице системных библиотек, которые не совместимы между собой. Возможно в будущем добавим поддержку дистрибутива для AlmaLinux 10 с v2.
Сейчас панель поддерживает только дистрибутив AlmaLinux 10 x86-64. Дистрибутив AlmaLinux 10 x86-64-v2 не поддерживается
