Ошибка Call to undefined function sem_get() при попытке обновления
DanielFin
Re: Ошибка Call to undefined function sem_get() при попытке обновления
Сообщение DanielFin » Пн фев 19, 2024 5:28 pm
>>> cat /etc/yum.repos.d/CentOS-Base.repo
# CentOS-Base.repo
# The mirror system uses the connecting IP address of the client and the
# update status of each mirror to pick mirrors that are updated to and
# geographically close to the client.  You should use this for CentOS updates
# unless you are manually picking other mirrors.
# If the mirrorlist= does not work for you, as a fall back you can try the
# remarked out baseurl= line instead.
[base]
name=CentOS-$releasever - Base
mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=os&infra=$infra
#baseurl=http://mirror.centos.org/centos/$releasever/os/$basearch/
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-7
#released updates
[updates]
name=CentOS-$releasever - Updates
mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=updates&infra=$infra
#baseurl=http://mirror.centos.org/centos/$releasever/updates/$basearch/
gpgcheck=1
#additional packages that may be useful
[extras]
name=CentOS-$releasever - Extras
mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=extras&infra=$infra
#baseurl=http://mirror.centos.org/centos/$releasever/extras/$basearch/
gpgcheck=1
#additional packages that extend functionality of existing packages
[centosplus]
name=CentOS-$releasever - Plus
mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=centosplus&infra=$infra
#baseurl=http://mirror.centos.org/centos/$releasever/centosplus/$basearch/
gpgcheck=1
enabled=0
>>> cat /etc/os-release
NAME="CentOS Linux"
VERSION="7 (Core)"
ID="centos"
ID_LIKE="rhel fedora"
VERSION_ID="7"
ANSI_COLOR="0;31"
Сообщение sbury » Пн фев 19, 2024 5:48 pm
у вас недоступны сервера CentOS 7
запустите эту строку в браузере
http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=os&infra=stock
попробуйте так же запустить обновление вашей ОС
yum update
DanielFin
Сообщение DanielFin » Пн фев 19, 2024 5:51 pm
Я то вижу, конечно, спиcок зеркал, а вот VPS видимо нет :cry:
Нужно, значит, писать хостеру
>>> yum update
Could not retrieve mirrorlist http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=os&infra=stock error was
12: Timeout on http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=os&infra=stock: (28, 'Connection timed out after 30001 milliseconds')
 One of the configured repositories failed (Unknown),
        or
        compromise:
Сообщение sbury » Пн фев 19, 2024 6:01 pm
да. пишите хостеру. У вас перекрыт доступ к серверам Centos
DanielFin
Сообщение DanielFin » Вт фев 20, 2024 8:35 am
Спасибо!
Подключился к яндекс зеркалу, обновил brainycp, поставил brainy-php5-process
Обновил сертификаты LE!
DanielFin
Сообщение DanielFin » Вт фев 20, 2024 3:38 pm
Та же история, те же ошибки, сертификаты работают
Crazy Demon писал(а):
Пт июл 07, 2023 8:21 am
Спасибо. Помогло.
При выполнении /home/dmitry# /usr/local/brainycp/src/compiled/php5/bin/php -q /usr/local/brainycp/scripts/letsen_renew.php
выдаются такие сообщения:
ipcrm: неверный id (52)
ipcrm: неверный id (53)
ipcrm: неверный id (54)
Failed to reload named.service: Unit named.service not found.
ipcrm: неверный id (55)
Renewing an existing certificate
ipcrm: неверный id (32768)
ipcrm: неверный id (32769)
ipcrm: неверный id (32770)
ls: невозможно получить доступ к 'b%%%n.ru*': Нет такого файла или каталога
ipcrm: неверный id (32779)
ipcrm: неверный id (32780)
ipcrm: неверный id (32781)
Failed to restart dovecot.service: Unit dovecot.service not found.
ipcrm: неверный id (32790)
ipcrm: неверный id (32791)
ipcrm: неверный id (32792)
ipcrm: неверный id (32793)
ipcrm: неверный id (32794)
sed: -e выражение #1, символ 1: неизвестная команда: `,'
ipcrm: неверный id (32804)
ipcrm: неверный id (32805)
ipcrm: неверный id (32806)
ls: невозможно получить доступ к 'j%%%k.ru*': Нет такого файла или каталога
ipcrm: неверный id (32815)
ipcrm: неверный id (32816)
ipcrm: неверный id (32817)
ipcrm: неверный id (32826)
ipcrm: неверный id (32827)
ipcrm: неверный id (32828)
ipcrm: неверный id (32829)
ipcrm: неверный id (32830)
ipcrm: неверный id (65543)
ipcrm: неверный id (65544)
ipcrm: неверный id (65545)
ls: невозможно получить доступ к 's%%%a.ru*': Нет такого файла или каталога
ipcrm: неверный id (65554)
ipcrm: неверный id (65555)
ipcrm: неверный id (65556)
ipcrm: неверный id (65565)
ls: невозможно получить доступ к 'v%%%s.ru*': Нет такого файла или каталога
ipcrm: неверный id (65566)
ipcrm: неверный id (65567)
Array
    [am%%%um.ru.conf] => Certificate not yet due for renewal , renewal date 2023-07-09
    [am%%%ws.ru.conf] => Certificate not yet due for renewal , renewal date 2023-07-09
    [a%%%cx.ru.conf] => Certificate not yet due for renewal , renewal date 2023-07-09
    [bl%%%sk.ru.conf] => Certificate not yet due for renewal , renewal date 2023-07-09
    [b%%%n.ru.conf] => renewok
    [d%%%s.ru.conf] => Certificate not yet due for renewal , renewal date 2023-07-09
    [de%%%to.ru.conf] => Certificate not yet due for renewal , renewal date 2023-07-09
    [de%%%in.ru.conf] => Certificate not yet due for renewal , renewal date 2023-07-09
    [j%%%k.ru.conf] => renewok
    [me%%%to.ru.conf] => Certificate not yet due for renewal , renewal date 2023-07-09
    [se%%%8s.ru.conf] => Certificate not yet due for renewal , renewal date 2023-07-09
    [s%%%a.ru.conf] => renewok
    [ts%%%sk.ru.conf] => Certificate not yet due for renewal , renewal date 2023-08-17
    [v%%%s.ru.conf] => renewok
    [xn%%%ai.conf] => Certificate not yet due for renewal , renewal date 2023-07-09
Как я понял, сообщения выдавались на домены с обновлёнными сертификатами.
Сертификаты сами выдались корректно. Просто ошибки напрягают сами по себе ...
