Ведутся ли работы в направлении форков CentOS
Re: Ведутся ли работы в направлении форков CentOS
Сообщение Akrobs » Ср сен 15, 2021 11:26 pm
Ср сен 15, 2021 3:22 pm
нужен лог установщика
Это из консоли
*******  INSTALL BRAINYCP CORE V3.01  *******
Detected OS Version: CentOS 8
Detected Server Name: alma.lan
Detected Server IP: 192.168.43.78
Detected Server RAM memory: 2025104 KB
Checking RAM size... PASS
Checking SWAP size... PASS
Checking type IP address... FAIL
The following issues were found:
 *) Your IP address is of a dynamic type (DHCP), but you need a static one.
    A dynamic address of a network interface can lead to incorrect operation of some services,
    for example, issuing certificates. And also, disrupting the installation process itself.
Please also note that technical support cannot help you until you fix these problems.
Continue installation? {y/n}: y
Continue and ignore these errors.
Download install script...  [OK]
WARNING!
If you are a CONTABO client. Please, read this post before continuing: https://community.brainycp.com/viewtopic.php?f=9&t=4004
Press CTRL+C to abort the installation.
if not, or is already fixed, press Enter to continue...
##########################(100%)
[DONE]
Type Script: KVM
Install tools network...   [OK]
======= Setup " apache2.4,nginx,php74w,bindserver,imagemagick,certbot,logrotate,MariaDB10.4,phpMyAdmin-4.9.4,exim,proftpd" ========
Configure process download...  [OK]
Download version...  [OK]
*******  BRAINYCP PANEL VERSION 1.09  ********
Install BrainyCP version 1.09
Wed Sep 15 23:18:50 MSK 2021
Disable SELINUX...       [OK]
Prepare install...       [OK]
Configure repo...  [OK]
Version os: 8
Architecture os: x86_64
Configure limits...  [OK]
Update THP Memory...   [OK]
Configure network...  [OK]
Run install script.
Install SSL...  [OK]
Run process Haveged
Install Haveged...  [OK]
Configure Haveged...  [OK]
Wed Sep 15 23:20:37 MSK 2021
Run Install process
Install package: dbus...                 [ERROR]
An error occurred, see the log file /root/install_pkg_L0.log for details.
[root@alma ~]#
Логи и остальное:
Logs.zip
(16.53 КБ) 1393 скачивания
Сообщение sbury » Чт сен 16, 2021 8:44 am
ls -l /etc/yum.repos.d
Сообщение Akrobs » Чт сен 16, 2021 10:59 am
[root@alma ~]# ls -l /etc/yum.repos.d
total 16
-rw-r--r--. 1 root root  941 Jul 29 16:55 almalinux-ha.repo
-rw-r--r--. 1 root root  961 Jul 29 16:55 almalinux-powertools.repo
-rw-r--r--. 1 root root 2660 Jul 29 16:55 almalinux.repo
-rw-r--r--. 1 root root 1190 Sep 15 23:43 brainy.repo
Сообщение Akrobs » Пт окт 22, 2021 12:28 pm
Есть какие-то новости по решению проблемы выше?
Сообщение Akrobs » Пн ноя 08, 2021 11:22 am
Попробовал установку снова, увидев, что внесли изменения в установочный скрипт. Теперь установка проходит без проблем, только одно ошибка в конце.
Configure SSL key... perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = (unset),
        LC_ALL = (unset),
        LANG = "koi8-r"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
