Установка/переустановка clamav [РЕШЕНО]
Добавлено: Пн окт 07, 2024 9:28 pm
При переустановке Exim+Dovecot+Mailclients как водится удалился антивирус. Переустановить не могу. Выдает ошибку
ERROR: Failed to lock the log file /var/log/clamav/freshclam.log: Resource temporarily unavailable
Tue Oct 8 00:24:31 2024 -> ClamAV update process started at Tue Oct 8 00:24:31 2024
Tue Oct 8 00:24:31 2024 -> !Can't create temporary directory /var/lib/clamav/tmp.5bb77e7873
Tue Oct 8 00:24:31 2024 -> Hint: The database directory must be writable for UID 125 or GID 129
Tue Oct 8 00:24:31 2024 -> !Update failed.
[OK]
Adding user clamav to group exim
Adding user clamsmtp to group exim
Lines removed succesfull
Complete
Run process...
Process completed.
[OK]
Complete
Run process...
Process completed.
