Неудачное соединение с IMAP сервером
Добавлено: Вт апр 20, 2021 2:38 pm
gregroy.nik
Здравствуйте!
Не могу настроить почтовый клиент. Что Roundcube, что Squiremail, бьют ошибку соединения с IMAP сервером. Буду очень благодарен, если подскажете как это дело пофиксить.
Ниже прикреплю логи по командам:
rpm -qa | grep dovecot
systemctl status dovecot
netstat -plunt | grep dovecot
[root@localhost ~]# rpm -qa | grep dovecot
dovecot-2.3.10-1.brainy.el8.x86_64
[root@localhost ~]# systemctl status dovecot
● dovecot.service - Dovecot IMAP/POP3 email server
   Loaded: loaded (/usr/lib/systemd/system/dovecot.service; enabled; vendor preset: disabled)
   Active: active (running) since Tue 2021-04-20 16:49:52 EEST; 45min ago
     Docs: man:dovecot(1)
           http://wiki2.dovecot.org/
 Main PID: 1822973 (dovecot)
    Tasks: 11 (limit: 10988)
   Memory: 11.6M
      CPU: 1.079s
   CGroup: /system.slice/dovecot.service
           ├─1822973 /usr/sbin/dovecot -F
           ├─1823011 dovecot/pop3-login
           ├─1823013 dovecot/anvil
           ├─1823014 dovecot/log
           ├─1823015 dovecot/pop3-login
           ├─1823016 dovecot/pop3-login
           ├─1823018 dovecot/imap-login
           ├─1823019 dovecot/config
           ├─1823021 dovecot/stats
           ├─1898550 dovecot/imap-login
           └─1898943 dovecot/imap-login
Apr 20 17:35:02 localhost.localdomain dovecot[1823014]: pop3-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1823011, input bytes=0
Apr 20 17:35:02 localhost.localdomain dovecot[1823014]: pop3-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1823015, input bytes=0
Apr 20 17:35:02 localhost.localdomain dovecot[1823014]: auth: Fatal: sql: Unknown database driver 'mysql'
Apr 20 17:35:02 localhost.localdomain dovecot[1822973]: master: Error: service(auth): command startup failed, throttling for 60.000 secs
Apr 20 17:35:37 localhost.localdomain dovecot[1823014]: imap-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1898943, input bytes=0
Apr 20 17:35:37 localhost.localdomain dovecot[1823014]: pop3-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1823011, input bytes=0
Apr 20 17:35:37 localhost.localdomain dovecot[1823014]: pop3-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1823016, input bytes=0
Apr 20 17:35:37 localhost.localdomain dovecot[1823014]: pop3-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1823015, input bytes=0
Apr 20 17:35:37 localhost.localdomain dovecot[1823014]: imap-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1898550, input bytes=0
Apr 20 17:35:37 localhost.localdomain dovecot[1823014]: imap-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1823018, input bytes=0
[root@localhost ~]# netstat -plunt | grep dovecot
tcp        0      0 0.0.0.0:110             0.0.0.0:*               LISTEN      1822973/dovecot
tcp        0      0 0.0.0.0:143             0.0.0.0:*               LISTEN      1822973/dovecot
tcp        0      0 0.0.0.0:993             0.0.0.0:*               LISTEN      1822973/dovecot
tcp        0      0 0.0.0.0:995             0.0.0.0:*               LISTEN      1822973/dovecot
tcp6       0      0 :::110                  :::*                    LISTEN      1822973/dovecot
tcp6       0      0 :::143                  :::*                    LISTEN      1822973/dovecot
tcp6       0      0 :::993                  :::*                    LISTEN      1822973/dovecot
tcp6       0      0 :::995                  :::*                    LISTEN      1822973/dovecot
Re: Неудачное соединение с IMAP сервером
Добавлено: Вт апр 20, 2021 4:18 pm
какая версия установлена базы данных?
Добавлено: Вт апр 20, 2021 6:46 pm
gregroy.nik
Базу ставил MariaDB 10.5
Добавлено: Ср апр 21, 2021 7:54 am
Ошибку исправили ожидайте новую сборку
Добавлено: Ср апр 21, 2021 6:05 pm
gregroy.nik
Как скоро ожидать новую сборку?
Добавлено: Чт апр 22, 2021 7:07 am
Уже есть.
Добавлено: Сб апр 24, 2021 10:10 pm
gregroy.nik
Уже есть.
Обновил панель, перезагрузил сервер, и к сожалению ошибка соединения с IMAP сервером осталась, что в Roundcube, что в Sqiuremail.
Добавлено: Пн апр 26, 2021 7:25 am
Обновлений еще нет, только доступно при чистой установке панели.
Напишите нам в чат, или скайп.
Добавлено: Сб июн 04, 2022 10:00 pm
nicksat
Возникла проблема с настройкой почты.
Раннее пользовался панелью на Centos 8, сейчас понадобилось переконфигурировать сервер и перешёл на AlmaLinux. Именно в этой ОС не получается настроить почту. При попытке авторизоваться в Roundcube или Squiremail выдает ошибку о неудачном соединении с IMAP сервером. В логах так же ругается Unknown database driver 'mysql' как у создателя темы. Помогите найти решение.
cat /etc/redhat-release
AlmaLinux release 8.5 (Arctic Sphynx)
dovecot-mysql10.5-2.3.10-1.brainy.el8.x86_64
dovecot-2.3.16-2.el8.x86_64
   Active: active (running) since Sun 2022-06-05 00:08:07 EEST; 39min ago
           https://doc.dovecot.org/
 Main PID: 1066 (dovecot)
    Tasks: 11 (limit: 18869)
   Memory: 14.0M
      CPU: 1.107s
           ├─ 1066 /usr/sbin/dovecot -F
           ├─ 1069 dovecot/pop3-login
           ├─ 1070 dovecot/imap-login
           ├─ 1071 dovecot/anvil
           ├─ 1072 dovecot/log
           ├─ 1073 dovecot/pop3-login
           ├─ 1074 dovecot/pop3-login
           ├─ 1077 dovecot/config
           ├─ 1079 dovecot/stats
           ├─21512 dovecot/imap-login
           └─21753 dovecot/imap-login
июн 05 00:46:30 some_sites.net dovecot[1072]: auth: Fatal: sql: Unknown database driver 'mysql'
июн 05 00:46:30 some_sites.net dovecot[1066]: master: Error: service(auth): command startup failed, throttling for 60.000 secs
июн 05 00:46:30 some_sites.net dovecot[1072]: imap-login: Error: auth-client: conn unix:login (pid=1066,uid=0): Timeout waiting for handshake from auth server. my pid=21753, input bytes=0
июн 05 00:47:00 some_sites.net dovecot[1072]: imap-login: Error: auth-client: conn unix:login (pid=1066,uid=0): Timeout waiting for handshake from auth server. my pid=21753, input bytes=0
июн 05 00:47:05 some_sites.net dovecot[1072]: imap-login: Error: auth-client: conn unix:login (pid=1066,uid=0): Timeout waiting for handshake from auth server. my pid=21512, input bytes=0
июн 05 00:47:05 some_sites.net dovecot[1072]: imap-login: Error: auth-client: conn unix:login (pid=1066,uid=0): Timeout waiting for handshake from auth server. my pid=1070, input bytes=0
июн 05 00:47:30 some_sites.net dovecot[1072]: auth: Error: Couldn't load plugin /usr/lib64/dovecot/auth/libdriver_mysql.so: Module is for different ABI version 2.3.ABIv10(2.3.10) (we have 2.3.ABIv16(2.3.16))
июн 05 00:47:30 some_sites.net dovecot[1072]: auth: Fatal: sql: Unknown database driver 'mysql'
июн 05 00:47:30 some_sites.net dovecot[1066]: master: Error: service(auth): command startup failed, throttling for 60.000 secs
июн 05 00:47:30 some_sites.net dovecot[1072]: imap-login: Error: auth-client: conn unix:login (pid=1066,uid=0): Timeout waiting for handshake from auth server. my pid=21753, input bytes=0
tcp        0      0 0.0.0.0:993             0.0.0.0:*               LISTEN      1066/dovecot
tcp        0      0 0.0.0.0:995             0.0.0.0:*               LISTEN      1066/dovecot
tcp        0      0 0.0.0.0:110             0.0.0.0:*               LISTEN      1066/dovecot
tcp        0      0 0.0.0.0:143             0.0.0.0:*               LISTEN      1066/dovecot
tcp6       0      0 :::993                  :::*                    LISTEN      1066/dovecot
tcp6       0      0 :::995                  :::*                    LISTEN      1066/dovecot
tcp6       0      0 :::110                  :::*                    LISTEN      1066/dovecot
tcp6       0      0 :::143                  :::*                    LISTEN      1066/dovecot
rpm -qa | grep mariadb
mariadb10.5-10.5.12-300.brainy.el8.x86_64
mariadb10.5-server-10.5.12-300.brainy.el8.x86_64
mariadb10.5-common-10.5.12-300.brainy.el8.x86_64
mariadb10.5-columnstore-engine-10.5.12-300.brainy.el8.x86_64
mariadb10.5-client-10.5.12-300.brainy.el8.x86_64
mariadb10.5-libs-10.5.12-300.brainy.el8.x86_64
mariadb10.5-server-utils-10.5.12-300.brainy.el8.x86_64
mariadb-libs-10.5.1-554.el8.x86_64
Добавлено: Вс июн 05, 2022 7:59 am
покажите вывод
rpm list installed | grep dovecot
