jokero
jokero » Вт дек 02, 2025 5:04 pm
Здравствуйте, не работает установка почтового сервиса на Almalinux
Лог установки Exim
Running transaction
Preparing : 1/1
Running scriptlet: clamav-db-0.103.8-1.brainy.el9.x86_64 1/1
/bin/chown: invalid user: ‘exim:exim’
error: %prein(clamav-db-0.103.8-1.brainy.el9.x86_64) scriptlet failed, exit status 1
Лог установки opendmarc
/usr/local/brainycp/ssh/packet_manager/opendmarc/opendmarc.sh install
Installing opendmarcLast metadata expiration check: 0:04:57 ago on Tue Dec 2 19:56:55 2025.
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages)
[OK]
Complete
ClamAV тоже не работает из-за Exim.
sbury » Ср дек 03, 2025 2:06 pm
Покажите выводы
cat /etc/os-release
rpm -qa | grep clam
rpm -qa | grep exim
alenka » Ср дек 03, 2025 3:01 pm
ls -al /etc/yum.repos.d/
jokero
jokero » Ср дек 03, 2025 7:07 pm
cat /etc/os-release
NAME="AlmaLinux"
VERSION="9.7 (Moss Jungle Cat)"
ID="almalinux"
ID_LIKE="rhel centos fedora"
VERSION_ID="9.7"
PLATFORM_ID="platform:el9"
PRETTY_NAME="AlmaLinux 9.7 (Moss Jungle Cat)"
ANSI_COLOR="0;34"
LOGO="fedora-logo-icon"
CPE_NAME="cpe:/o:almalinux:almalinux:9::baseos"
ALMALINUX_MANTISBT_PROJECT="AlmaLinux-9"
ALMALINUX_MANTISBT_PROJECT_VERSION="9.7"
REDHAT_SUPPORT_PRODUCT_VERSION="9.7"
SUPPORT_END=2032-06-01
Команды:
Ничего не вывели.
Команда
total 92
drwxr-xr-x. 2 root root 4096 Dec 2 18:02 .
drwxr-xr-x. 134 root root 12288 Dec 2 20:58 ..
-rw-r--r-- 1 root root 232 Jan 2 2023 alma-brainy.repo
-rw-r--r-- 1 root root 1013 Dec 2 18:01 almalinux-appstream.repo
-rw-r--r-- 1 root root 977 Dec 2 18:01 almalinux-baseos.repo
-rw-r--r-- 1 root root 951 Sep 5 2024 almalinux-crb.repo
-rw-r--r-- 1 root root 941 Nov 11 13:10 almalinux-crb.repo.rpmnew
-rw-r--r-- 1 root root 977 Nov 11 13:10 almalinux-extras.repo
-rw-r--r-- 1 root root 1097 Nov 11 13:10 almalinux-highavailability.repo
-rw-r--r-- 1 root root 941 Nov 11 13:10 almalinux-nfv.repo
-rw-r--r-- 1 root root 953 Nov 11 13:10 almalinux-plus.repo
-rw-r--r-- 1 root root 1097 Nov 11 13:10 almalinux-resilientstorage.repo
-rw-r--r-- 1 root root 929 Nov 11 13:10 almalinux-rt.repo
-rw-r--r-- 1 root root 989 Nov 11 13:10 almalinux-saphana.repo
-rw-r--r-- 1 root root 941 Nov 11 13:10 almalinux-sap.repo
-rw-r--r-- 1 root root 1195 Dec 2 18:02 brainy.repo
-rw-r--r-- 1 root root 288 Nov 16 19:05 dedi.repo
-rw-r--r-- 1 root root 811 Nov 16 19:06 docker-ce.repo
-rw-r--r-- 1 root root 2402 Sep 5 2024 mysql-community.repo
-rw-r--r-- 1 root root 91 Sep 5 2024 ul_auto.repo
-rw-r--r-- 1 root root 144 Sep 5 2024 ul.repo
sbury » Чт дек 04, 2025 11:49 am
Покажите выводы
yum list installed | grep mariadb
yum install -y exim
У вас есть подключения нестандартных репозитариев. Есть подозрение, что с каким то из них происходит конфликт
jokero
jokero » Чт дек 04, 2025 6:40 pm
mariadb-libs.x86_64 34:99.99.1-558.el9 @8_sql
mariadb11.4.x86_64 4:11.4.5-3.brainy.el9_9.5 @8_sql
mariadb11.4-client.x86_64 4:11.4.5-3.brainy.el9_9.5 @8_sql
mariadb11.4-common.x86_64 4:11.4.5-3.brainy.el9_9.5 @8_sql
mariadb11.4-libs.x86_64 4:11.4.5-3.brainy.el9_9.5 @8_sql
mariadb11.4-server.x86_64 4:11.4.5-3.brainy.el9_9.5 @8_sql
mariadb11.4-server-utils.x86_64 4:11.4.5-3.brainy.el9_9.5 @8_sql
yum install -y exim
Brainy v9 Brainy 7.1 kB/s | 2.9 kB 00:00
Brainy v9 APP 9.2 kB/s | 2.9 kB 00:00
Brainy v9 SQL 9.3 kB/s | 2.9 kB 00:00
Brainy v9 PHP 16 kB/s | 2.9 kB 00:00
Brainy v9 Brainy 10 kB/s | 2.9 kB 00:00
Brainy v9 python 17 kB/s | 2.9 kB 00:00
HG Dedi Repo 21 kB/s | 2.9 kB 00:00
Docker CE Stable - x86_64 63 kB/s | 2.0 kB 00:00
Docker CE Stable - x86_64 846 kB/s | 64 kB 00:00
MySQL 8.0 Community Server 361 kB/s | 3.0 kB 00:00
MySQL Connectors Community 564 kB/s | 3.0 kB 00:00
MySQL Tools Community 350 kB/s | 3.0 kB 00:00
UL 21 kB/s | 2.9 kB 00:00
UL_auto 20 kB/s | 2.9 kB 00:00
Error:
Problem: package libgsasl-1.10.0-3.el9.x86_64 from myrepo-centos requires libidn.so.11()(64bit), but none of the providers can be installed
- package libgsasl-1.10.0-3.el9.x86_64 from myrepo-centos requires libidn.so.11(LIBIDN_1.0)(64bit), but none of the providers can be installed
- cannot install both libidn-1.34-5.el9.x86_64 from myrepo-centos and libidn-1.38-4.el9.x86_64 from @System
- package exim-4.94.2-1.brainy.el9.x86_64 from 8_app requires libgsasl.so.7()(64bit), but none of the providers can be installed
- package exim-4.94.2-1.brainy.el9.x86_64 from 8_app requires libgsasl.so.7(LIBGSASL_1.1)(64bit), but none of the providers can be installed
- package perl-Net-LibIDN-0.12-39.el9.x86_64 from @System requires libidn.so.12()(64bit), but none of the providers can be installed
- package perl-Net-LibIDN-0.12-39.el9.x86_64 from @System requires libidn.so.12(LIBIDN_1.0)(64bit), but none of the providers can be installed
- conflicting requests
- problem with installed package perl-Net-LibIDN-0.12-39.el9.x86_64
jokero
jokero » Пт дек 05, 2025 8:37 pm
Что я могу в данном случае сделать? Кроме того, что искать другой сервер с норм. ОС?
sbury » Пт дек 05, 2025 9:44 pm
jokero писал(а): ↑Пт дек 05, 2025 8:37 pm
выводы
yum list installed | grep libidn
yum list installed | grep perl-Net-LibIDN
yum install libidn
jokero
jokero » Пт дек 05, 2025 10:34 pm
sbury писал(а): ↑Пт дек 05, 2025 9:44 pm
выводы
yum install libidn
Спасибо за ответ.
libidn.x86_64 1.38-4.el9 @epel
libidn2.x86_64 2.3.0-7.el9 @anaconda
perl-Net-LibIDN.x86_64 0.12-39.el9 @@commandline
yum install libidn
Last metadata expiration check: 0:51:13 ago on Sat 06 Dec 2025 12:42:29 AM MSK.
Package libidn-1.38-4.el9.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!
jokero
jokero » Пт дек 05, 2025 10:38 pm
выводы
yum install libidn
Возможно это как-то поможет:
grep -r "repo-centos" /etc/yum.repos.d/
/etc/yum.repos.d/brainy.repo:[myrepo-centos]
/etc/yum.repos.d/alma-brainy.repo:[myrepo-centos]
