Не удаётся установить Mysq\MariDB
Добавлено: Чт янв 16, 2020 8:27 pm
gdvden
Здравствуйте!
Параметры установки собирал через конструктор на сайте. Там же выбирал и mysql. Но в процессе он так и не установился. При попытке установить mysql или mariadb через панель выдает следующие
Starting install MySQL MariaDB10.4
Install MySQL MariaDB10.4
Starting find Version
Install Server MYSQL 10.4...
CentOS-8 - AppStream                            2.1 MB/s | 5.8 MB     00:02
CentOS-8 - Base                                 4.3 MB/s | 4.0 MB     00:00
CentOS-8 - Extras                               3.6 kB/s | 2.1 kB     00:00
Brainy v8 Base                                  780 kB/s | 289 kB     00:00
Brainy v8 APP                                   238 kB/s |  70 kB     00:00
Brainy v8 SQL                                   469 kB/s | 163 kB     00:00
Brainy v8 PHP                                   312 kB/s |  99 kB     00:00
Brainy v8 Brainy                                 95 kB/s |  22 kB     00:00
Brainy v8 python                                1.0 kB/s | 257  B     00:00
No match for argument: mariadb10.4-server
No match for argument: exim-mysql10.4
No match for argument: dovecot-mysql10.4
No match for argument: mariadb10.4-server-utils
Error: Unable to find a match: mariadb10.4-server exim-mysql10.4 dovecot-mysql10.4 mariadb10.4-server-utilsStarting postinstall
correct mysql
Memory detected: 3871660
END OF INSTALL
/etc/brainy/ssh/pkg_manager_init.php -a update_file_config
Run process...
Process completed.
/etc/brainy/src/compiled/php5/bin/php -q  /etc/brainy/scripts/cluster.php -a sinhronisation_cluster -f 'packet'
%5B%7B%22comm%22%3A%22%5C%2Fetc%5C%2Fbrainy%5C%2Fssh%5C%2Fpacket_manager%5C%2Fmysql%5C%2Fmysql.php+-a%3Dinstall+-s%3DMySql5.5%22%2C%22array_succes%22%3A%7B%22status_mysql%22%3A%22success%2C%23stream_id%23%22%2C%22mysql%22%3A%221%22%2C%22mysql_version%22%3A%22MySql5.5%22%7D%2C%22array_start%22%3A%7B%22status_mysql%22%3A%22inprogress%2C%23stream_id%23%22%7D%2C%22array_unsucces%22%3A%7B%22status_mysql%22%3A%22unsuccess%2C%23stream_id%23%22%7D%2C%22test%22%3A%22END+OF+INSTALL%22%2C%22userowner%22%3A%22root%22%7D%2C%7B%22comm%22%3A%22%5C%2Fetc%5C%2Fbrainy%5C%2Fssh%5C%2Fpkg_manager_init.php+-a+update_file_config%22%7D%2C%7B%22comm%22%3A%22%5C%2Fetc%5C%2Fbrainy%5C%2Fsrc%5C%2Fcompiled%5C%2Fphp5%5C%2Fbin%5C%2Fphp+-q++%5C%2Fetc%5C%2Fbrainy%5C%2Fscripts%5C%2Fcluster.php+-a+sinhronisation_cluster+-f+%27packet%27%22%7D%5D/etc/brainy/data/streams/packet_manager2_control_157920673264894
/etc/brainy/ssh/packet_manager/mysql/mysql.php -a=install -s=MySql5.5
Starting install MySQL MySql5.5
Install MySQL MySql5.5
Install Server MYSQL 5.5...
CentOS-8 - AppStream                            3.3 MB/s | 5.8 MB     00:01
CentOS-8 - Base                                 3.9 MB/s | 4.0 MB     00:01
CentOS-8 - Extras                                11 kB/s | 2.1 kB     00:00
Brainy v8 Base                                  856 kB/s | 289 kB     00:00
Brainy v8 APP                                   228 kB/s |  70 kB     00:00
Brainy v8 SQL                                   449 kB/s | 163 kB     00:00
Brainy v8 PHP                                   331 kB/s |  99 kB     00:00
Brainy v8 Brainy                                113 kB/s |  22 kB     00:00
Brainy v8 python                                1.3 kB/s | 257  B     00:00
No match for argument: mysql55
No match for argument: mysql55-server
No match for argument: exim-mysql55
No match for argument: dovecot-mysql55
Error: Unable to find a match: mysql55 mysql55-server exim-mysql55 dovecot-mysql55Starting postinstall
correct mysql
END OF INSTALL
Run process...
Process completed.
Что делать, как дальше жить? )
Re: Не удаётся установить Mysq\MariDB
Добавлено: Пт янв 17, 2020 8:22 am
Свяжитесь с нами в чате, или скайп.
Добавлено: Пт янв 17, 2020 8:24 am
Стоп, у вас centos 8 ?
Панель еще не поддерживает данную ос.
Добавлено: Пт янв 17, 2020 10:18 am
Centos 8 в стадии разработки, о чем инсталлятор предупреждает. На текущий момент 8 предназначена для тестеров
Добавлено: Сб янв 18, 2020 5:40 pm
gdvden
Да, спасибо за отклик. Установил на centos 7
Добавлено: Пт авг 16, 2024 2:45 pm
yanistyle
Такая же беда на ubuntu 20.04, решил установить MySQL 8 и теперь вообще ничего не устанавливается
Добавлено: Пт авг 16, 2024 2:52 pm
Покажите лог установки.
Добавлено: Чт сен 19, 2024 12:30 pm
Taylory
у меня на almalinux тож беда была. удалил и заного мариад по новее версию поставил
Добавлено: Пт сен 20, 2024 7:38 am
Без лога установки помочь мы вряд ли чем то сможем
