Обновление до 1.09, все упало
Добавлено: Вс сен 05, 2021 4:12 pm
Отлетела панель, и вместе с ней все сайты, пытался реанимировать по совету из этого
поста https://community.brainycp.com/viewtopic.php?f=3&t=4435
но ничего не вышло, забуксовал на команде
yum install brainy-nginx
[root@bcp ~]# yum clean all
36 files removed
[root@bcp ~]# systemctl stop nginxb
Failed to stop nginxb.service: Unit nginxb.service not loaded.
[root@bcp ~]# systemctl stop brainyphp-fpm
Failed to stop brainyphp-fpm.service: Unit brainyphp-fpm.service not loaded.
[root@bcp ~]# yum remove brainy-nginx
No match for argument: brainy-nginx
No packages marked for removal.
Dependencies resolved.
Nothing to do.
Complete!
[root@bcp ~]# yum remove brainy-php5*
No match for argument: brainy-php5*
Nothing to do.
Complete!
[root@bcp ~]# yum install brainy-nginx
CentOS Linux 8 - AppStream 2.6 MB/s | 8.8 MB 00:03
CentOS Linux 8 - BaseOS 3.5 MB/s | 5.6 MB 00:01
CentOS Linux 8 - Extras 32 kB/s | 10 kB 00:00
Brainy Repo el7 5.6 MB/s | 6.3 MB 00:01
Brainy Repo el7 119 kB/s | 27 kB 00:00
Brainy Repo el7 1.4 MB/s | 631 kB 00:00
Error:
Problem: package brainy-nginx-2:1.20.1-18.brainy.el7.x86_64 requires brainy-nginx-all-modules = 2:1.20.1-18.brainy.el7, but none of the providers can be installed
- package brainy-nginx-all-modules-2:1.20.1-18.brainy.el7.noarch requires brainy-nginx-mod-http-image-filter = 2:1.20.1-18.brainy.el7, but none of the providers can be installed
- cannot install the best candidate for the job
- nothing provides libgd.so.2()(64bit) needed by brainy-nginx-mod-http-image-filter-2:1.20.1-18.brainy.el7.x86_64
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
[root@bcp ~]#
