Ошибка install SSL при установке на CentOS 8
Добавлено: Вс июн 14, 2020 8:30 pm
При установке на чистый centOS методом:
Выдается ошибка на шаге INSTALL SSL
4.18.0-80.11.2.el8_0.x86_64
[root@stunning-cavallo ~]# df
devtmpfs 2002500 0 2002500 0% /dev
tmpfs 2017696 0 2017696 0% /dev/shm
tmpfs 2017696 8576 2009120 1% /run
tmpfs 2017696 0 2017696 0% /sys/fs/cgroup
/dev/sda1 59014680 926720 55545940 2% /
tmpfs 403536 0 403536 0% /run/user/0
[root@stunning-cavallo ~]# selinux
-bash: selinux: command not found
HTOP:
yum clean all && yum install -y wget && wget http://core.brainycp.ru/install.sh && bash ./install.sh
uname -rRunning scriptlet: wget-1.19.5-8.el8_1.1.x86_64 1/2
Running scriptlet: wget-1.19.5-7.el8_0.1.x86_64 2/2
Cleanup : wget-1.19.5-7.el8_0.1.x86_64 2/2
Verifying : wget-1.19.5-8.el8_1.1.x86_64 1/2
Verifying : wget-1.19.5-7.el8_0.1.x86_64 2/2
Upgraded:
Complete!
--2020-06-14 20:37:27-- http://core.brainycp.ru/install.sh
Resolving core.brainycp.ru (core.brainycp.ru)... 185.181.165.8
Connecting to core.brainycp.ru (core.brainycp.ru)|185.181.165.8|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 7354 (7.2K) [application/x-sh]
Saving to: 'install.sh'
install.sh 100%[===================>] 7.18K --.-KB/s in 0s
2020-06-14 20:37:27 (59.7 MB/s) - 'install.sh' saved [7354/7354]
Virtualization test: PASS
Detected OS Version: CentOS 8
Script KVM\n
Install tools network... [OK]
======= Setup maximum configuration ========
Download version... [OK]
Install BrainyCP version 1.07
Sun Jun 14 20:38:09 UTC 2020
Disable SELINUX... [OK]
Prepare install... [OK]
Configure repo... [OK]
Version os: 8
Architecture os: x86_64
Configure limits... [OK]
Configure network... [OK]
Run install script.
Install SSL... [ERROR]
HTOP:
