Добавлено: Вс фев 17, 2019 12:55 pm
stratovariors
Bootstrapping dependencies for RedHat-based OSes... (you can skip this with --no-bootstrap)
yum is /usr/bin/yum
yum is hashed (/usr/bin/yum)
* base: mirror.awanti.com
* epel: mirror.awanti.com
* extras: mirror.awanti.com
* updates: mirror.awanti.com
Package gcc-4.8.5-36.el7.x86_64 already installed and latest version
Package 1:openssl-1.0.2k-16.el7.x86_64 already installed and latest version
Package ca-certificates-2018.2.22-70.0.el7_5.noarch already installed and latest version
Resolving Dependencies
--> Running transaction check
---> Package augeas-libs.x86_64 0:1.4.0-6.el7_6.1 will be installed
---> Package libffi-devel.x86_64 0:3.1-16.el7.centos will be installed
--> Processing Dependency: libffi = 3.1-16.el7.centos for package: libffi-devel-3.1-16.el7.centos.x86_64
---> Package openssl-devel.x86_64 1:1.0.2k-16.el7 will be installed
--> Processing Dependency: krb5-devel(x86-64) for package: 1:openssl-devel-1.0.2k-16.el7.x86_64
---> Package python-devel.x86_64 0:2.7.5-76.el7 will be installed
---> Package python-pip.noarch 0:10.0.1-2.el7.centos will be installed
---> Package python-tools.x86_64 0:2.7.5-76.el7 will be installed
--> Processing Dependency: tkinter = 2.7.5-76.el7 for package: python-tools-2.7.5-76.el7.x86_64
---> Package python-virtualenv.noarch 0:15.1.0-2.el7 will be installed
---> Package redhat-rpm-config.noarch 0:9.1.0-87.el7.centos will be installed
--> Processing Dependency: dwz >= 0.4 for package: redhat-rpm-config-9.1.0-87.el7.centos.noarch
--> Processing Dependency: perl-srpm-macros for package: redhat-rpm-config-9.1.0-87.el7.centos.noarch
---> Package dwz.x86_64 0:0.11-3.el7 will be installed
---> Package krb5-devel.x86_64 0:1.15.1-37.el7_6 will be installed
--> Processing Dependency: libkadm5(x86-64) = 1.15.1-37.el7_6 for package: krb5-devel-1.15.1-37.el7_6.x86_64
--> Processing Dependency: krb5-libs(x86-64) = 1.15.1-37.el7_6 for package: krb5-devel-1.15.1-37.el7_6.x86_64
--> Processing Dependency: libverto-devel for package: krb5-devel-1.15.1-37.el7_6.x86_64
--> Processing Dependency: libselinux-devel for package: krb5-devel-1.15.1-37.el7_6.x86_64
--> Processing Dependency: libcom_err-devel for package: krb5-devel-1.15.1-37.el7_6.x86_64
--> Processing Dependency: keyutils-libs-devel for package: krb5-devel-1.15.1-37.el7_6.x86_64
---> Package libffi.x86_64 0:3.0.13-18.el7 will be updated
---> Package libffi.x86_64 0:3.1-16.el7.centos will be an update
---> Package perl-srpm-macros.noarch 0:1-8.el7 will be installed
---> Package tkinter.x86_64 0:2.7.5-76.el7 will be installed
--> Processing Dependency: libtk8.5.so()(64bit) for package: tkinter-2.7.5-76.el7.x86_64
--> Processing Dependency: libtcl8.5.so()(64bit) for package: tkinter-2.7.5-76.el7.x86_64
--> Processing Dependency: libTix.so()(64bit) for package: tkinter-2.7.5-76.el7.x86_64
---> Package keyutils-libs-devel.x86_64 0:1.5.8-3.el7 will be installed
---> Package krb5-libs.x86_64 0:1.15.1-34.el7 will be updated
---> Package krb5-libs.x86_64 0:1.15.1-37.el7_6 will be an update
---> Package libcom_err-devel.x86_64 0:1.42.9-13.el7 will be installed
---> Package libkadm5.x86_64 0:1.15.1-37.el7_6 will be installed
---> Package libselinux-devel.x86_64 0:2.5-14.1.el7 will be installed
--> Processing Dependency: libsepol-devel(x86-64) >= 2.5-10 for package: libselinux-devel-2.5-14.1.el7.x86_64
--> Processing Dependency: pkgconfig(libsepol) for package: libselinux-devel-2.5-14.1.el7.x86_64
---> Package libverto-devel.x86_64 0:0.2.5-4.el7 will be installed
---> Package tcl.x86_64 1:8.5.13-8.el7 will be installed
---> Package tix.x86_64 1:8.4.3-12.el7 will be installed
---> Package tk.x86_64 1:8.5.13-6.el7 will be installed
---> Package libsepol-devel.x86_64 0:2.5-10.el7 will be installed
Dependencies Resolved
Package Arch Version Repository Size
Installing:
augeas-libs x86_64 1.4.0-6.el7_6.1 updates 355 k
libffi-devel x86_64 3.1-16.el7.centos myrepo-centos 18 k
openssl-devel x86_64 1:1.0.2k-16.el7 base 1.5 M
python-devel x86_64 2.7.5-76.el7 base 398 k
python-pip noarch 10.0.1-2.el7.centos myrepo-centos 1.9 M
python-tools x86_64 2.7.5-76.el7 base 856 k
python-virtualenv noarch 15.1.0-2.el7 base 1.7 M
redhat-rpm-config noarch 9.1.0-87.el7.centos base 81 k
Installing for dependencies:
dwz x86_64 0.11-3.el7 base 99 k
keyutils-libs-devel x86_64 1.5.8-3.el7 base 37 k
krb5-devel x86_64 1.15.1-37.el7_6 updates 271 k
libcom_err-devel x86_64 1.42.9-13.el7 base 31 k
libkadm5 x86_64 1.15.1-37.el7_6 updates 178 k
libselinux-devel x86_64 2.5-14.1.el7 base 187 k
libsepol-devel x86_64 2.5-10.el7 base 77 k
libverto-devel x86_64 0.2.5-4.el7 base 12 k
perl-srpm-macros noarch 1-8.el7 base 4.6 k
tcl x86_64 1:8.5.13-8.el7 base 1.9 M
tix x86_64 1:8.4.3-12.el7 base 254 k
tk x86_64 1:8.5.13-6.el7 base 1.4 M
tkinter x86_64 2.7.5-76.el7 base 326 k
Updating for dependencies:
krb5-libs x86_64 1.15.1-37.el7_6 updates 803 k
libffi x86_64 3.1-16.el7.centos myrepo-centos 26 k
Transaction Summary
Install 8 Packages (+13 Dependent packages)
Upgrade ( 2 Dependent packages)
Total download size: 12 M
Is this ok [y/d/N]: Exiting on user command
Your transaction was saved, rerun it with:
yum load-transaction /tmp/yum_save_tx.2019-02-17.12-41.v1N5vC.yumtx
Could not install OS dependencies. Aborting bootstrap!
Re: Ошибка генерации сертификата. Домен должен быть привязан!
Добавлено: Вс фев 17, 2019 12:57 pm
stratovariors
Домен привязан к серверу уже трое суток. Менял в настройках днс ip. Причем на сайт спокойно установил wordpress через встроенный в панел ь установщик, сайт работает вполне стабильно. В чем может быть дело? Помогите пожалуйста!
Добавлено: Пн фев 18, 2019 2:10 pm
Свяжитесь с нами в скайпе, или чате, мы проверим данный ньюанс.
Судя по лугу возможно ошибка в зависимостях, попробуйте переустановить CertBOT, через пакетный менеджер.
Добавлено: Ср фев 27, 2019 2:10 am
NovEes
Доброго времени суток!)
У меня такая-же проблема была при тестах, так что велком решение в студию)
Добавлено: Ср фев 27, 2019 9:23 am
Данная проблема встретилась у хостера Beget.
Конфликт пакета python2-pip (который установлен с репозитария epel)
Выполните команду в терминале.
yum -y remove python2-pip
После этого переустановите сертбот.
Добавлено: Ср фев 27, 2019 12:24 pm
stratovariors
Так и не понял что делать. Как связаться с вами в скайпе?
Добавлено: Ср фев 27, 2019 12:44 pm
Чат на сайте https://brainycp.com/ или на сайте также есть кнопка Написать в скайп
