Предложение и замечания по Nginx
Pahom-ka
Сообщение Pahom-ka » Ср дек 18, 2019 8:57 am
Добрый день!
[root@vm857534 ~]# nginx -V
nginx version: nginx/1.16.0
built with OpenSSL 1.1.1c  28 May 2019
TLS SNI support enabled
configure arguments: --prefix=/usr/share/nginx --add-module=/root/rpmbuild/BUILD/modsecurity-2.9.2/nginx/modsecurity --add-module=/root/diff/nginx-push-stream-module-master --sbin-path=/usr/sbin/nginx --modules-path=/usr/lib64/nginx/modules --conf-path=/etc/nginx/nginx.conf --error-log-path=/var/log/nginx/error.log --http-log-path=/var/log/nginx/access.log --http-client-body-temp-path=/var/lib/nginx/tmp/client_body --http-proxy-temp-path=/var/lib/nginx/tmp/proxy --http-fastcgi-temp-path=/var/lib/nginx/tmp/fastcgi --http-uwsgi-temp-path=/var/lib/nginx/tmp/uwsgi --http-scgi-temp-path=/var/lib/nginx/tmp/scgi --pid-path=/run/nginx.pid --lock-path=/run/lock/subsys/nginx --user=nginx --group=nginx --with-file-aio --with-ipv6 --with-http_ssl_module --with-http_v2_module --with-http_realip_module --with-http_addition_module --with-http_xslt_module=dynamic --with-http_image_filter_module=dynamic --with-http_geoip_module=dynamic --with-http_sub_module --with-http_dav_module --with-http_flv_module --with-http_mp4_module --with-http_gunzip_module --with-http_gzip_static_module --with-http_random_index_module --with-http_secure_link_module --with-http_degradation_module --with-http_slice_module --with-http_stub_status_module --with-http_perl_module=dynamic --with-http_auth_request_module --with-mail=dynamic --with-mail_ssl_module --with-pcre --with-pcre-jit --with-stream=dynamic --with-stream_ssl_module --with-stream_ssl_preread_module --with-openssl=/root/diff/openssl-1.1.1c --with-openssl-opt=enable-tls1_3 --with-google_perftools_module --add-dynamic-module=/root/rpmbuild/BUILD/ngx_brotli --add-dynamic-module=/root/rpmbuild/BUILD/nginx-cache-purge-0.1 --add-dynamic-module=/root/rpmbuild/BUILD/headers-more-nginx-module-0.33 --add-dynamic-module=/root/rpmbuild/BUILD/ngx_pagespeed-1.13.35.2-stable --add-dynamic-module=/root/rpmbuild/BUILD/redis2-nginx-module-0.15 --add-dynamic-module=/root/rpmbuild/BUILD/nginx-rtmp-module-1.2.1 --with-cc-opt='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -m64 -mtune=generic' --with-ld-opt='-Wl,-z,relro -specs=/usr/lib/rpm/redhat/redhat-hardened-ld -Wl,-E'
Также неплохо в секции events в nginx.conf указать:
   use epoll;
Также в секции http надо добавить:
http2_push_preload on;
без этой настройки все пуши через nginx не работают так, как должны.
изменить
worker_processes auto;
добавить
multi_accept on;
очень не хватает модуля gzip_static, в то время как brotli с поддержкой предварительно сжатых файлов есть.
Ещё некорректно работает переадресация, если одновременно выбрать http->https, и www->non-www.
