Перестала грузиться панель
Re: Перестала грузиться панель
curl 'http://127.0.0.1:8002'
в первой дирректории ничего не открывается. Там есть access.log и error.log. Но видимо они пустые. Так и есть:sbury писал(а): ↑Пн окт 14, 2024 8:30 amЧто влогах?Код: Выделить всё
/var/log/nginxb /var/log/brainyphp-fpm
[root@hw1 brainyphp-fpm]# cd /var/log/nginxb
[root@hw1 nginxb]# ls -l
total 0
-rw-r--r-- 1 root root 0 Oct 4 19:48 access.log
-rw-r--r-- 1 root root 0 Oct 4 19:48 error.log
Во второй вот:
[root@hw1 brainyphp-fpm]# ls -l
total 8
-rw------- 1 root root 3298 Oct 14 12:11 error.log
-rw-r--r-- 1 root root 113 Oct 14 05:07 www-error.log
[root@hw1 brainyphp-fpm]# cat error.log
[04-Oct-2024 19:48:43] NOTICE: fpm is running, pid 20348
[04-Oct-2024 19:48:43] NOTICE: ready to handle connections
[04-Oct-2024 19:48:43] NOTICE: systemd monitor interval set to 10000ms
[14-Oct-2024 04:34:23] NOTICE: fpm is running, pid 589
[14-Oct-2024 04:34:23] NOTICE: ready to handle connections
[14-Oct-2024 04:34:23] NOTICE: systemd monitor interval set to 10000ms
[14-Oct-2024 10:43:40] WARNING: [pool brainy.conf] seems busy (you may need to i ncrease pm.start_servers, or pm.min/max_spare_servers), spawning 8 children, the re are 0 idle, and 5 total children
[14-Oct-2024 10:43:41] WARNING: [pool brainy.conf] seems busy (you may need to i ncrease pm.start_servers, or pm.min/max_spare_servers), spawning 16 children, th ere are 0 idle, and 6 total children
[14-Oct-2024 10:57:58] NOTICE: Terminating ...
[14-Oct-2024 10:57:58] NOTICE: exiting, bye-bye!
[14-Oct-2024 10:58:20] NOTICE: fpm is running, pid 579
[14-Oct-2024 10:58:20] NOTICE: ready to handle connections
[14-Oct-2024 10:58:20] NOTICE: systemd monitor interval set to 10000ms
[14-Oct-2024 11:05:06] NOTICE: Terminating ...
[14-Oct-2024 11:05:06] NOTICE: exiting, bye-bye!
[14-Oct-2024 11:05:43] NOTICE: fpm is running, pid 580
[14-Oct-2024 11:05:43] NOTICE: ready to handle connections
[14-Oct-2024 11:05:43] NOTICE: systemd monitor interval set to 10000ms
[14-Oct-2024 11:25:30] NOTICE: Terminating ...
[14-Oct-2024 11:25:30] NOTICE: exiting, bye-bye!
[14-Oct-2024 11:28:05] NOTICE: fpm is running, pid 576
[14-Oct-2024 11:28:05] NOTICE: ready to handle connections
[14-Oct-2024 11:28:05] NOTICE: systemd monitor interval set to 10000ms
[14-Oct-2024 11:32:51] NOTICE: Terminating ...
[14-Oct-2024 11:32:51] NOTICE: exiting, bye-bye!
[14-Oct-2024 11:32:51] NOTICE: fpm is running, pid 2840
[14-Oct-2024 11:32:51] NOTICE: ready to handle connections
[14-Oct-2024 11:32:51] NOTICE: systemd monitor interval set to 10000ms
[14-Oct-2024 11:38:40] NOTICE: Terminating ...
[14-Oct-2024 11:38:40] NOTICE: exiting, bye-bye!
[14-Oct-2024 11:38:40] NOTICE: fpm is running, pid 4289
[14-Oct-2024 11:38:40] NOTICE: ready to handle connections
[14-Oct-2024 11:38:40] NOTICE: systemd monitor interval set to 10000ms
[14-Oct-2024 11:41:05] NOTICE: Terminating ...
[14-Oct-2024 11:41:05] NOTICE: exiting, bye-bye!
[14-Oct-2024 11:41:43] NOTICE: fpm is running, pid 589
[14-Oct-2024 11:41:43] NOTICE: ready to handle connections
[14-Oct-2024 11:41:43] NOTICE: systemd monitor interval set to 10000ms
[14-Oct-2024 11:43:43] NOTICE: Terminating ...
[14-Oct-2024 11:43:43] NOTICE: exiting, bye-bye!
[14-Oct-2024 11:43:43] NOTICE: fpm is running, pid 2001
[14-Oct-2024 11:43:43] NOTICE: ready to handle connections
[14-Oct-2024 11:43:43] NOTICE: systemd monitor interval set to 10000ms
[14-Oct-2024 12:06:44] NOTICE: Terminating ...
[14-Oct-2024 12:06:44] NOTICE: exiting, bye-bye!
[14-Oct-2024 12:07:21] NOTICE: fpm is running, pid 587
[14-Oct-2024 12:07:21] NOTICE: ready to handle connections
[14-Oct-2024 12:07:21] NOTICE: systemd monitor interval set to 10000ms
[14-Oct-2024 12:11:37] NOTICE: Terminating ...
[14-Oct-2024 12:11:37] NOTICE: exiting, bye-bye!
[14-Oct-2024 12:11:37] NOTICE: fpm is running, pid 2591
[14-Oct-2024 12:11:37] NOTICE: ready to handle connections
[14-Oct-2024 12:11:37] NOTICE: systemd monitor interval set to 10000ms
[root@hw1 brainyphp-fpm]# cat www-error.log
[14-Oct-2024 02:37:12 Europe/Kiev] PHP Notice: Undefined index: check in /usr/local/brainycp/auth.php on line 0
[root@hw1 ~]# curl 'http://127.0.0.1:8002'
<link rel="stylesheet" type="text/css" href="/tpl/basic/css/auth.css" />
<link href='https://fonts.googleapis.com/css?family ... llic,latin' rel=stylesheet type='text/css'>
<link rel="stylesheet" href="/tpl/basic/font/css/font-awesome.min.css">
<title>BrainyCP — страница авторизации</title>
<script src="//ajax.googleapis.com/ajax/libs/jquery/1.10.2/jquery.min.js"></script>
<div class="wrapper">
<div class="container">
<div class="form-group">
<img class="logo" src="/tpl/basic/img/auth/logo.png" alt="Brainy">
<form class="auth-form" action="auth.php" method="post">
<div>
<i class="fa fa-user" aria-hidden="true"></i><input type="text" name="login" placeholder="Логин" />
</div>
<div>
<i class="fa fa-lock" aria-hidden="true"></i><input type="password" name="password" placeholder="Пароль" />
</div>
<input type="hidden" name="lan" value= />
<input type="submit" id="log2brainy" value="Войти" />
</form>
</div>
</div>
</div>
<script>
$('.auth-form input').keydown(function(){$('.auth-err').fadeOut();})
</script>
Вы используету NAT или csf сервис?
нет, не использую
По данному ответу панель у вас работает.Metalcore писал(а): ↑Пн окт 14, 2024 10:59 am[root@hw1 ~]# curl 'http://127.0.0.1:8002'
<div>
</div>
<div>
</div>
</form>
</div>
</div>
</div>
<script>
</script>
Проверьте фаервол, может проброс портов на вашем оборудовании, а также правильность написания портов.
https: Порт 8000
http: Порт 8002
пробовал с двух разных провайдеров. Пробовал через впн. Написание исключено, потому что я захожу по сохраненным ссылкам. Причем до перезагрузки после установки php5 все нормально работало вполне. а после перезагрузки как отрубило. Я тоже не могу понять пока в чем причина.
Панель не работает на php5, который устанавливается через связку. Он работает на brainyphp-fpm(который у вас рабочий.)Metalcore писал(а): ↑Пн окт 14, 2024 1:20 pmпробовал с двух разных провайдеров. Пробовал через впн. Написание исключено, потому что я захожу по сохраненным ссылкам. Причем до перезагрузки после установки php5 все нормально работало вполне. а после перезагрузки как отрубило. Я тоже не могу понять пока в чем причина.
Эта команда, отдала ответ что сама панель у вас рабочая.(локально)
Проверьте iptables, может у вас заблокированы 8002 и 8000 порты
покажите вывод
ip a s
[root@hw1 ~]# ip a s
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:16:3e:9a:a9:09 brd ff:ff:ff:ff:ff:ff
altname enp0s3
altname ens3
inet 46.175.144.66/21 brd 46.175.151.255 scope global noprefixroute eth0
inet6 fe80::216fe9a:a909/64 scope link
altname enp0s3
altname ens3
