Почему именно в 15:00?
YurgenTM
Сообщение YurgenTM » Вт мар 07, 2023 3:17 pm
Подскажите, почему рестарт происходит ежедневно именно в 15:00, где поменять настройку сервера?
[Tue Mar 07 15:00:04.285783 2023] [mpm_worker:notice] [pid 12832:tid 140231201404992] AH00297: SIGUSR1 received.  Doing graceful restart
AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using XX.XX.XX.XX. Set the 'ServerName' directive globally to suppress this message
[Tue Mar 07 15:00:04.395371 2023] [lbmethod_heartbeat:notice] [pid 12832:tid 140231201404992] AH02282: No slotmem from mod_heartmonitor
[Tue Mar 07 15:00:04.398972 2023] [mpm_worker:notice] [pid 12832:tid 140231201404992] AH00292: Apache/2.4.46 (BrainyCP - Sasha Bury) OpenSSL/1.0.2r-fips configured -- resuming normal operations
[Tue Mar 07 15:00:04.400628 2023] [core:notice] [pid 12832:tid 140231201404992] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Tue Mar 07 15:00:04.423999 2023] [mpm_worker:notice] [pid 12832:tid 140231201404992] AH00296: caught SIGWINCH, shutting down gracefully
[Tue Mar 07 15:00:52.780333 2023] [suexec:notice] [pid 28996:tid 140696152619072] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Mar 07 15:00:52.780398 2023] [:notice] [pid 28996:tid 140696152619072] ModSecurity for Apache/2.9.2 (http://www.modsecurity.org/) configured.
[Tue Mar 07 15:00:52.780415 2023] [:notice] [pid 28996:tid 140696152619072] ModSecurity: APR compiled version="1.5.2"; loaded version="1.5.2"
[Tue Mar 07 15:00:52.780432 2023] [:notice] [pid 28996:tid 140696152619072] ModSecurity: PCRE compiled version="8.32 "; loaded version="8.32 2012-11-30"
[Tue Mar 07 15:00:52.780446 2023] [:notice] [pid 28996:tid 140696152619072] ModSecurity: LUA compiled version="Lua 5.1"
[Tue Mar 07 15:00:52.780455 2023] [:notice] [pid 28996:tid 140696152619072] ModSecurity: LIBXML compiled version="2.9.1"
[Tue Mar 07 15:00:52.780464 2023] [:notice] [pid 28996:tid 140696152619072] ModSecurity: Status engine is currently disabled, enable it by set SecStatusEngine to On.
[Tue Mar 07 15:00:52.845505 2023] [lbmethod_heartbeat:notice] [pid 28996:tid 140696152619072] AH02282: No slotmem from mod_heartmonitor
[Tue Mar 07 15:00:52.869359 2023] [mpm_worker:notice] [pid 28996:tid 140696152619072] AH00292: Apache/2.4.46 (BrainyCP - Sasha Bury) OpenSSL/1.0.2r-fips configured -- resuming normal operations
[Tue Mar 07 15:00:52.869445 2023] [core:notice] [pid 28996:tid 140696152619072] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
Re: Почему именно в 15:00?
Сообщение alenka » Ср мар 08, 2023 9:09 am
free -h
cat /var/log/messages | grep memory
какая версия панели и какая ос?
YurgenTM
Сообщение YurgenTM » Ср мар 08, 2023 9:40 am
free -h
# free -h
Mem:           23Gi       6.3Gi        14Gi       1.3Gi       2.2Gi        15Gi
Swap:         4.0Gi          0B       4.0Gi
cat /var/log/messages | grep memory - ничего не выводит
BrainyCP Текущая версия: 1.0946.20230223
CentOS Linux 7
Сообщение alenka » Ср мар 08, 2023 10:33 am
Панель сама не перезапускает сервисы, если они не упали.
Сообщение sbury » Ср мар 08, 2023 1:30 pm
Apache/2.4.46
Данная версия апачи устарела. Текущая версия для панели
Apache/2.4.54
YurgenTM
Сообщение YurgenTM » Чт мар 09, 2023 8:13 am
Apache/2.4.46
Apache/2.4.54
Подскажите, а можно как-то обновить Apache из админки? Стараюсь из строки что-то запускать по минимуму.
Сообщение alenka » Чт мар 09, 2023 8:32 am
Какая у вас версия панели?
YurgenTM
Сообщение YurgenTM » Чт мар 09, 2023 8:34 am
1.0946.20230223
Сообщение alenka » Чт мар 09, 2023 8:52 am
Связку переустановите. На момент переустановки связки, сайты будут недоступны.
YurgenTM
Сообщение YurgenTM » Чт мар 09, 2023 10:28 am
Спасибо, попробую
